Old 11-24-2010, 09:10 AM   #1
vipola
There is a ground contact on the Becker's frame, with the radio removed, it is not grounded, leading to the alarm chirp. Locate it and ground it, the chirp will stop.....
I may be wrong but I think there is also a little non-conductive pad on the side of the radio, so if someone try to 'SLIDE' the radio out.. the ground contact will occure and start the alarm..
I suggest simply taking a look at those trigger and create contact or isolation to make it happy
vipola is offline   Reply With Quote
