Old 11-22-2010, 01:15 AM   #1
Steve Tinker
Steve Tinker's Avatar
The oil gets to its optimum working (hot) temperature only after about 5-6 miles of driving under normal conditions. The overall oil temperature is controlled (up to a point) by the coolant temperature via the oil / water heat exchanger mounted on top of the crankcase.
One way of causing oil contamination is to drive short distances in cold, humid climates at low temps - this causes high water & fuel contamination to the oil.
2001 MV Agusta F4.
