Old 11-19-2010, 12:42 PM   #1
yelojkt
Originally Posted by the_village_idiot
Does the soft top really leak?! Im surprised at that??? Not a surprise in a 15 year olf MX5- but a Boxster? Is this a common problem?
Indeed i will have it professionally inspected before i pay!
The soft top on the boxster is made like the sunroof in a VW it is not waterproof when closed but instead directs the water where it needs to go so as not to damage the car, such as drain tubes. On the boxster these plugs get clogged and then the water goes into the car instead of oput under the car. All you have to do is put the top in service position and make sure your tubes are clean. A friend of mine took her leaking Turbo-S into the stealership and they quoted her $1200 for a new sunroof. I fixed her leaky sunroof in 15 minutes with a piece of wire a drill and a water bottle.
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
yelojkt is offline   Reply With Quote
