Old 11-15-2010, 08:14 PM   #7
tightbox
So, did this fix work in the end? I'm having the exact same issues. The engine cut out around a corner, cluster says "engine failure" and engine won't even turn over.
It started ONCE after replacing the 25 amp C1 fuse, and ran fine for 20+ minutes. Shut her down, and tried to restart, it wouldn't turn over, and won't again (15 fuses into testing!)
C1 blows immediately before even turning key to crank position. Chased everything I can think of down w/ elec tester. Tried new battery, swapped "53" relays, new ignition switch, tested red/green wire going from DME to fuse panel.
Any idea where the wire your dealer spliced is located?
tightbox is offline   Reply With Quote
