Old 11-11-2010, 10:54 PM   #1
Jinster
Spinnaker, with that description in the Bentley manual, it all makes sense now.
The "L" shaped piece connects to the door handle on the other end. The connection is made by snapping a plastic connector onto a screw, the position on the screw this "snap on" occurs is variable. If the "L" is not in the right position when the door handle is connected, then you would have trouble with the length of the connection impeding the operation of the door handle and DLM. So the wire spring clip holds it in place during installation.
97 Boxster, have you resolved your DLM problems yet?
j.fro, yep, no speaker or airbag.
I actually opened up the door to install the silver interior door handle. So I compared the other side. The spring clip is also not connected, obviously.
--1989 Mazda MX6 GT
--1997 Porsche Boxster
--2005 Lexus RX330
--2007 Maserati Quattroporte Sport GT
Jinster is offline   Reply With Quote
