Old 11-09-2010, 09:09 PM   #2
BerneseMtnDog
I haven't done the water pump but the AOS is pretty straight forward. Make sure you get the lower boot part as well as the upper tube part that goes from the AOS to the engine. There are two different kinds of upper tube I believe so make sure of what you're ordering. Everything is accessed from above and the only tricky part is getting at those nasty spring clamps at the bottom of the AOS. I used a variety of pliers until I found one that would work in the space allowed.
Steve
2000 2.7L
BerneseMtnDog is offline   Reply With Quote
