Old 11-06-2010, 11:30 PM   #3
shlim8
Hmmm,
the "new" rims are actually original cayman 17" rims. The only thing was the offset for the rear are further out. The front offset for the front is the same. I had all 4 rims tested without tires - spun on a balancing machine without tyres. All straight.
The front tires are brand new Michellin Pilot Sport 3 (not N specs). I do have a mismatch between front and rear tires - the rears are 2yr old Aspec Db. Had not changed them yet as thread >95% and there was no stock for the tire size I needed.
No spacers - had bad experience with them on my 944.
I had checked my tire pressure and the rears were 2 psi off. Got that fixed and the car now feels more fluid and goes around corners pretty balanced in the dry. What a difference the tire pressure makes. But unfortunately vibration is still there. I still have to take it easy in the wet, but that's prob due to the aspect db tires - those things have no grip in the wet.
Looks like I got to find a Hunter Road Force machine locally, heard there one.
Or hopefully when I get the suspension swapped out they'll find a cracked top suspension mount or knocking strut !!!! ha ha...
shlim8 is offline   Reply With Quote
