Old 10-20-2010, 02:09 PM   #1
sd_boxster
There is an unused rubber grommet in the driver-side footwell, above the accelerator pedal. You can poke a hole in it to get the RCA cables into the battery area.
I drilled a hole from the frunk into the battery area - very close to the brake booster - to pass the RCA cables into the frunk area. If you're reluctant to drill, there is another rubber grommet between the frunk and the battery area toward the passenger side of the frunk.
1999 Carrera 4 • Aero kit • 4" UD Pulley
My Corvette doesn't leak oil... it sweats horsepower.
sd_boxster is offline   Reply With Quote
