Old 10-20-2010, 08:51 AM   #1
schoir
Originally Posted by yellowboxster01
There's foam coming out of my air vents? It's decintegrated flaky foam. Where is this coming from? I just had my 60K mile maintenance done. Did they miss some sort of in cabin filter?
Yellow:
The foam that helps to seal the various flaps begins to disintegrate at some point in a Boxster's life. There is a straightforward fix, which involves getting access from outside the car, at the base of the windshield, behind the location of the battery. That will give you access to the heater core location and access to the flaps that must be repaired.
There was a very detailed DIY on carboncow.net, but that link doesn't work anymore. Go on RennTech.org and send a PM to "rsfeller" ("Shawn") and ask him for the DIY that he created. He is always very helpful.
Regards, Maurice.
schoir is offline   Reply With Quote
