Old 10-07-2010, 08:46 PM   #33
dirkdiggler
Kevin
Mine is definitely positioned a little higher than yours is in the picture......... does it matter just as long as it is pointed in that general direction.
I also put the put back in and siliconed the green cap before I checked on the timing of the other banks
the motor does turn over by turning the pulley and does not bind or get stuck on anything.
I think I should be ok.
if the timing is off on the 4-6 banks will my motor blow up if I start it?
dirkdiggler is offline   Reply With Quote
