Old 10-06-2010, 06:44 AM   #1
insite
okay, i just saw in another thread that you have a '97.
now we need to check the timing. set your engine to TDC. on each head, there should be one side w/ two green plugs and another side w/ one green plug on the camshaft ends.
on the sides w/ two plugs, pull the lower plug out (exhaust cam). the notches in the ends of the cams should be perfectly vertical. if they're off significantly, you'll need to re-time.
i plan on posting that procedure later today w/ photos.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
