Old 07-19-2005, 09:08 AM   #2
deliriousga
deliriousga's Avatar
Try hardwood floor skids.
I can't help you find a replacement, but maybe I can help you keep them. Ours rattle so I picked up some hardwood floor self-stick rubber skid pads. I'm cutting them into small pieces to stick on the screens between the screen and the roll bar. It should tighten it up and since it's rubber it should also help it hold on to the roll bar a little tighter. Just don't put them directly behind the three clips so they don't push the clip in. If you cut it small enough to be inside the channel then you should not be able to see it once it's installed.
1966 Wife White/Brown Top
