Old 09-23-2010, 12:20 PM   #2
insite
Originally Posted by 06boxster
Granted, by replacing the clutch you will have to add the extra money for the clutch kit, but not replacing it would be silly!
Here is why, if you don't do it and it goes out in a few K miles, then you have to do the whole nine yards all over again and you'd kick yourself in the rear.
This is also a good opportunity to think "upgrade" to a performance or street/race clutch.
Yes I know, it will add somewhere from $500 all the way to $1300 to your tab, but it is worth every dime.
Check out those links I found for you.
totally agree. BTW, the stage 1 clutch from Spec is only around $550 and is rated to 340lb-ft of torque. and an Aasco LWF is only another $800 on top of that......what a slippery slope indeed.
EDIT: the $550 from Spec is for the disk, pressure plate, throwout bearing and alignment tool. available sprung or unsprung.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
