Old 07-18-2005, 07:13 AM   #4
RandallNeighbour
Originally Posted by deliriousga
So if I disconnect the battery cable and let the car sit for 45 minutes before I disconnect the wiring harness and take the seat out it won't do the light thing anymore?
Do I have to make sure the seat is plugged back in before I reconnect the battery terminal to keep it from happening?
Yes, in the future, when you remove seats or disconnect something wired into the airbag system, the light will not come on if you've disconnected the battery and let the car sit 30+ minutes. Some might say you don't need to wait this long or at all, but my mechanic says this assures the system has been drained or bled of any remnant or residual voltage, wattage or amperage (...whichever one is right. I can't remember).
And Yes, you MUST plug in the seat connections before you reconnect the battery or you'll receive the same idiot light burning a hole into your forehead every time you turn on your car. Remove stuff for repair or replacement in the right order and reassemble the car in the reverse order and you'll be fine.
Stop the madness! :dance:
Man, I hate those idiot lights, especially the CE light because it can mean a million things!
