Thread: Door Speakers
Old 07-17-2005, 12:37 PM   #4
bigislandboxster
I upgraded to a Nakamichi CD400 head unit, Focal 4" 2 way component speakers in the dash using the stock grilles, Focal 5 3/8" subs in the doors, and a 4 channel Audison amp 60w x 4......I like the results a lot! Those little subs can really kick it out! The Nak has a separate sub output, so I just ran that to the rear input on the amp and set the low pass on the amp at 50hz.....One thing I didn't do that I may go back and do, is fill the small area where the sub is with that cotton filler like you use for fish tank filters.....Might make the bass even a tad more tighter sounding.....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
