Old 08-21-2010, 05:10 PM   #2
brp987
As I recall, the scissor site plans call for 4" thick concrete floor. I never verified that so just in case I got 3 pieces of 4' x 8" x 3/8" steel sheet. One for each roller and one for the stationary end. That also provides a smooth surface. If your floor is uneven or rough I'd get that taken care of first. You don't want to risk binding the mechanism or have bad distribution of forces.
The pump cart has a peg that plugs into the lift allowing the pump cart to be used as a dolly to move the lift around your garage.
brp987 is offline   Reply With Quote
