Thread: car won't lock!
Old 08-20-2010, 05:31 PM   #31
Bladecutter
Originally Posted by 97 Boxster
OK, I re soldered the joint as discussed in earlier posts and this did NOT work. The short seems to be in the harness going into the door lock mechanism. When the battery is plugged in all I have to do to get the window to drop and the light to turn on is touch the harness where it goes into the door lock mechanism. This is the same with both mechanisms that I have tried. I have spent hours trying to resolve this issue. Can anybody help please? I have noticed a little wiggle room in the harness where it plugs into the door lock mechanism and when I wiggle this it works as it should. As soon as I let it go it shuts off (the light) and the window goes back up like the door is closed. Could this be a reset issue? When I say reset I mean could I have to do the memory up and down with my windows to get it to work properly? Of course when I am working on all this my door is opened so I am not sure how to best test this. Its a pain to put the door panel back on just to find out its still the same. Thanks.
All you need to do is trace which wire it is in the harness that is having the issue.
Use either a circuit light, or a DVOM, and test each wire's continuity to ground to see if its one wire in particular that is having the issue, then back track it through to the car body, and see if the harness was pinched somewhere between.
If it's just one wire, you can easily splice in a new wire to fix it.
Enough testing, and you might even be able to find the break point, and fix it there.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
