After reading this again, sounds like it is indeed your litronic bulb.
I had the same issue awhile back, and replaced my bulbs, and worked like a charm.
You're on the right path... Swap bulbs side to side, and see how that results..
If I remember correctly, it is a D2S bulb. PM me if you need help finding a cheap replacement.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
