Old 07-31-2010, 08:00 AM   #27
SoCalKen
Originally Posted by code7
I De-Snorked mine today. I have a 98' and man was it a pane in the ass to get the vent off. In the process I was lucky enough to break one of those dame clips that are attached to the grill slits. The one I broke was the forward most to the front of the car. I reinstalled the deal and its a little more loose now but not that it will effect anything (I hope). I like the new sound of the engine now. Sounds great. AS for removing the vent I did research on it but it seems there is now easy way to get it off...I guess I'm lucky I only broke one clip
If you still have the broken clip you can repair it. If I remember correctly you can use actone to weld it back together, if tha doesn't work use CA glue. then get some 2 part epoxy to build around it for some extra support. of course put the epoxy in areas that won't interfere with reinstallation.
Ken
SoCalKen is offline   Reply With Quote
