Originally Posted by husker boxster
I notice a difference in ride height when I go from my std 19s down to my 18" snows, so you're probably correct about riding higher when going from 17s to 18s. The 18s you now have should fill out the wheel opening better. Is it that big of a deal? It's not like you put a set of 22s on.
The rolling diameter should be the same when going to a plus sized wheel/tire. Lower profile tire side walls deflect less at the road at a given air pressure. So if you are doing it right, the larger tires should have a slightly smaller sized diameter. This makes them the same rolling diameter. So the larger profile wheel and tire combo should actually fill in the wheel well less than the smaller wheel.
It's probable that if the car is riding higher, the tires are the wrong size.
