Old 07-26-2010, 04:38 AM   #8
Dave S.
Dave S.'s Avatar
Originally Posted by Viper5
PROBLEM SOLVED!!!
I went to a local bike shop to try and get one of those brake adjustors, but they didn't have what I wanted. I'm not sure how exactly Dave was going to hook it up that way. So then I went to autozone to see if they had anything that could grab the wire and pull it together closer. Nothing. I decided to go back home and take it apart again and see if there was anything further I could do. I noticed that the wire was still a bit looser than I had wanted, so in order to tighten it further, I had to take that spring piece out of the socket on the topside to fit another ziptie in. It seemed like it had a decent tightness to it so I put it back together with the sacrifice of having that piece not go in the slot it was designed to and it works perfectly for now. Like it was new and mimics the drivers side.
Thank you so much everyone for your help!
Glad it worked for you also.
I was careful not to pull any of the outer sleeves from the holes they go into at their ends because I wanted to make sure the cable didn't chafe against anything. The cable end acts a guide to ensure the cable has a straight shot to the wheel in each corner and to the regulator driver assembly in the middle. I found that you can use a single wire tie on any given end and up two on the spring end that goes into the regulator. Of course the lower front corner (behind the door speaker) is the easiest to get to.
I also didn't want to disable the spring mechanism where the cable goes into the bottom of the regulator as it absorbs a shock load when the window hits the stops that limit the window travel. I used wire tie spacers to pre-load the spring a bit more.
In any event, the investment to try this fix is so minimal it's worth it. If it doesn't work you are only as bad off as you were before.
Dave S.
2003 Boxster S
Dave S. is offline   Reply With Quote
