Old 07-25-2010, 11:43 AM   #6
Viper5
PROBLEM SOLVED!!!
I went to a local bike shop to try and get one of those brake adjustors, but they didn't have what I wanted. I'm not sure how exactly Dave was going to hook it up that way. So then I went to autozone to see if they had anything that could grab the wire and pull it together closer. Nothing. I decided to go back home and take it apart again and see if there was anything further I could do. I noticed that the wire was still a bit looser than I had wanted, so in order to tighten it further, I had to take that spring piece out of the socket on the topside to fit another ziptie in. It seemed like it had a decent tightness to it so I put it back together with the sacrifice of having that piece not go in the slot it was designed to and it works perfectly for now. Like it was new and mimics the drivers side.
Thank you so much everyone for your help!
Viper5 is offline   Reply With Quote
