Old 07-25-2010, 06:46 AM   #13
Viper5
My wire is also a bit loose so I put some ties on there and tested it out. It was definitely working. So I put everything back together and at first it was still working but the window would come maybe twice as far as it normally does and would still come up correctly, but then it stopped doing that. I'll just take it apart again and see what I can do.
Upon further inspection, it's almost as if the window is stuck when the top is up. When I am just testing the window when it's not shut using a screwdriver or something where the switch is, the window does seem to go up and down the normal distance. As soon as I shut the door with the top up, it doesn't have the same range of motion. When the top is down, it works again. I think this is why I thought it was working at first (because the door wasn't shut)
Viper5 is offline   Reply With Quote
