I really like the car alot but am also very nervous. Its a blast to drive.
I went to start it this morning and it would not turn over or start ....... took heat gun too the electrical box again ........... and was able to get it started and running.
It idled a little rough and the check engine light came on and was blinking/flashing for about 40 seconds and then just stayed illuminated solid.
I just took it too autozone to have them run the codes.
apparently every cylinder 1-6 has a Miss-fire now and a oxygen sensor code also.
Im assuming the electrical box may be beyond saving and is causing the miss-fires and "check engine light too flash and then stay on ........... I dont know for sure.
Im going to see if the guy will take $3k for the car considering a new electrical box will need to be bought ...... for sure I think...... dont want to be left stranded becasue the electrical box issue.
Do these car typically have a sorta high pitch "exhaust note" sound at idle??
