Old 07-21-2010, 07:42 AM   #13
gwoodburn
Originally Posted by Banana S
Bump to possibly get my question answered, since otherwise it's likely to get lost in the Troll Chow.
http://www.lnengineering.com/ims.html
The prices are at the bottom of the page.
$895 = Upgrade
$519-$595 = Retrofit
If its labor your talking about, then the Retrofit should cost you an additional 2-3 hours on top of a clutch job. Depending on what the hourly rate is in your area I would say maybe an additional $200-$300. If it is a double row bearing, it may take a bit longer because they can be harder to remove. The Upgrade requires the engine be completely disassembled so I don't really know a dollar amount. You probably do not want to go that route unless you have another reason to disassemble the engine.
2003 Porsche Boxster S
gwoodburn is offline   Reply With Quote
