Old 07-19-2010, 01:39 PM   #21
jcb986
jcb986's Avatar
Thumbs up the AOS installed...it needs to right on or your problem will not go away. The J-tube on top is usually replaced at the same time. Also the lower tube can fail and crack or suck air around the orings. I would check the AOS to be sure it is in correct. There is a place it goes into the block and the notorious boot...usually this is where you might get a problem.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
