Old 07-16-2010, 07:25 PM   #2
seningen
seningen's Avatar
+1 on GTA_G20 -- you might even be able to do it faster than it took him
to type it -- nice write up!
Mike
QUOTE=GTA_G20]You need to start by removing the rear spoiler first.
-Raise the spoiler manually w/ the switch near the dead pedal(or the rear spoiler switch if you've done that mod)
-Open the rear trunk so you don't mess it up while work
-Get a center punch,small nail or something you can tap the middle of the three rivets out with
-remove the rear spoiler cover
-Remove the two bolts located inside the spoiler by looking downwards within the spoiler
-Lift and remove spoiler
Now removing the rear bumper
-Remove the bumperettes by releasing their bolt. You can see the bolt when you get on the ground and look on your back
-remove the wheel well housing screw, 1/side
-remove the three screws located on the bottom of the bumper, 3/side
-remove the screws from the license plate lighting,2/per light
-release the lights from the bumper
thanks to Blinkwatt[/QUOTE]
seningen is offline   Reply With Quote
