Old 07-15-2010, 08:45 PM   #2
986rgt
Send a message via AIM to 986rgt
The spoiler goes up at 75mph, and goes down at 55mph. You can't really see it from in the car unless you have the sun kinda off to the back right of the car, then you can see the shadow of the wing when it goes up. If the wing fails to go up or down when it is supposed to, you will get the spoiler light on the dash that lights up when you start the car(this is the one that goes off after you drive forward a few feet). If you raise the wing manually using the rocker switch in the footwell, then it will stay up until you either lower it manually, or after you go over 75 then drop below 55 if I remember correctly.
Hope this helps.
Steve
986rgt is offline   Reply With Quote
