Old 07-11-2010, 05:01 PM   #1
Scbrindley
Originally Posted by extanker
if they use the thin tin nuts you may need to pull as you remove
Thanks for the quick response. Can you please be a little more specific? The hole under the hood to access the nut is very small. How should I go about pulling the nut from the back while using the 8mm socket?
Thanks again.
'99 Boxster - Ocean Blue/Graphite Grey
http://i6.photobucket.com/albums/y22...y/IMG_0937.jpg
Scbrindley is offline   Reply With Quote
