Old 07-02-2010, 10:42 AM   #5
Dave S.
Dave S.'s Avatar
So after trying the reset, with no success, I took the door apart and found that the window has exceessive play in the regulator cabling system allowing the widow to move about 1/2 inch up and down when it isn't rolled all the up or all the way down. The driver's side window shows no such play in the system.
How can this be adjusted so the cables are tighter.
I can't believe the regulator itself is worn out since this car only has 20k miles on it and it's the passenger side, which is used less than the driver's side.
Dave S.
2003 Boxster S
Dave S. is offline   Reply With Quote
