Old 07-01-2010, 08:01 AM   #1
jcb986
jcb986's Avatar
First check your fluid level...if it's ok I would suspect the pump could be failing and not supplying enough fluid to the rack or the rack could be by-passing fluid. Since the system is basically sealed with fluid moving though all the time I would not consider a blocked line. Post what you find, it helps everyone here.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
