Old 06-28-2010, 11:11 AM   #1
jhandy
like pk2 said, they may need to be reset.
first un plug your battery. then hook it back up. you can tell if they have been reset because when you tap the switch, they dont auto go down like they did before.
now. with the top up and locked, door closed, put the window up and down , and up and down, and up and down.... you can tell when the computer learned when you tap the switch and the window auto goes down.
now open the door, the window should drop.
if it still hangs than you know you have a physical problem rather than an electrical.
the door rails are known to crap out. I would carfully take off the door panel at this point and look to the window on the rails, see if it is hung up on some junk like a piece of broken sound proofing.
while you are at it hit the rails and the gears with some white lithium grease in a spray can.
that should do it.
2002 S
jhandy is offline   Reply With Quote
