Old 06-26-2010, 02:19 PM   #2
70Sixter
There are also empty fuse slots for connections.
As Chris said, the phone cable has switched +12 VDC, unswitched +12, mute and ground. Just pull the carpeted panel by your right leg gently back and down to access.
I bought a connector from Becker so I would not have to spice into the harness.
While you are in there it is a good time to hardwire your radar detector and/or 12 VDC garage door opener. I just left the detector there and it works fine.
Why constant power? It will run down the battery.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
