Having been inside my door panel for some work, I believe the locksmith is correct. There is a rod that clicks into a rod holder that allows the door lock mechanism to work. I found that removing the door panel was easy so it is fairly easy to access, but you have to be careful not to force any of the plastic parts apart or they may break.
Good luck.
