Old 06-24-2010, 08:57 AM   #4
Bellster
Advice from other forum site only took one nite now hard top can go to spray painters tomorrow, just if anyone else would like to know here how to remove roof strips..
Roof strips pop right out - there are plastic clips (~4) under each strip that grip on threaded studs protruding from the channel under the strip. Replacement clips are cheap - plan on replacing them for reassembly.
Rubber is screwed on with each screw cleverly tucked under the folds of rubber. Some are real tough to find. Consider leaving the rubber in place and tape it. You can loosen it to better mask for painting...
I won't be taping anything everthing will be removed and respayed professionally.
Thanks again for you info ddb you helped heaps too m8........
Bellster is offline   Reply With Quote
