Old 06-20-2010, 02:59 PM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
It is normal for the dash lights to stay on for 5 minutes after you pull out the key, unless you lock the car (in which case they go out right away). However, if the lights do not go out even after 5 minutes, then it could be that your clock reset/mileage reset knobs are stuck in the pushed in position, or your ignition switch is starting to act funny.
