Old 06-19-2010, 07:47 AM   #4
sb01box
Originally Posted by jaykay
Thanks.....yes it is already buttoned up! I still cant envision exactly how it works but I think this process would still require you to have cable markings............the green thing locked to the shifter is way too far away to indicate cable placement..............I am really curious now
Based on my one time experience of swapping out 01 shift lever with stock 997 shifter.
I think the green clip holds the shift lever for both the up/down and left/right "by-design" neutral position. With the Transmission set at neutral, cable acts as intermediate piece connecting the two ends.
my installation had the driver side cable 1/4 of an inch short of the original resting point on its cradle. The passenger side cable/cradle was exactly at the marking.
In retrospect, had I removed the green clip and pulled the driver side cradle back to match the marking, the unit would have been tight in engaging 1st and 2nd gear.
sb01box is offline   Reply With Quote
