My drivers window drops 1/4". but goes back up when the handle is released.
The interior door lights stay on as if the door is open when it is shut.
Can you please with this problem.
Thanks,
Glenn
Originally Posted by MNBoxster
Hi,
Welcome Back BTW! Standardizing the Windows is required anytime the Battery, the wiring harness or the Motor are disconnected. The Power Window Regulator loses it's reference point for the Closed Position.
To re-establish this, you need to fully raise the Windows (with the Top up) and hold the switch depressed after the Window reaches its peak for 5 sec.
Also, you lose the one-touch control after the same types of interuptions and so must also re-establish this. This is done by running the Window one complete cycle - Up/Down without interuption. Hope this helps...
Happy Motoring!.... Jim'99
