Old 06-13-2010, 07:51 AM   #1
Cartel
Originally Posted by ekam
Boxtaboy:
So how did you mate them together? I assume you have to re-use your 986 boot trim and remove the 987 boot trim off the 987 shifter. Nice looking console as well.
Cartel:
I would strongly suggest you to get the padded steering wheel unless the alcantara version is also padded (ie. thicker than stock). It's a big difference for sure.
This is the steering wheel I was contemplating purchasing, it appears to be the same unit as the stock unit minus the alcantara.
http://www.****************************************************.com/product/gt3rs996whe.html?Category_Code=996gt3knobs
By padded steering wheels, are you by chance speaking of the one below?
http://www.****************************************************.com/product/CarbonWheel986996.html?Category_Code=996gt3knobs
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l GiroDisc 340mm FR Rotors l IPD Intake Plenum l Litronics l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
Cartel is offline   Reply With Quote
