Old 07-02-2005, 05:50 PM   #1
bigislandboxster
Well, a little update.....Its been a lot longer because some stuff was backordered, and I was missing a few smaller items as well......This was the first time I ever installed on any car, and I have to tip my hat to Rod Birch at Car Audio Innovations in California .....He gave me pretty detailed instructions on how to do this, and it helped a lot. Thanks bud!
I wanted to keep things pretty stealthy.....The speakers in the doors were the 5 3/8" Focal subs, they were a tight fit, and I had to trim a little of the plastic surround on the door to fit the metal frame supporting the speakers, but other than that, pretty easy. Same went for the dash speakers, although I had Rod premount these as they needed a little customizing to get them to fit in the existing mounts. The stock Boxster grilles were used so things remain stock looking(tho not sounding!) Focal Polyglass 2 way components there 4" bass/mid and 1" tweeter.....These babies sound sweet! They handle the power well also....
The Nakamichi CD400 looks sweet in the dash, very understated by todays standards. Very user friendly too, I had it figured out real quick...Not too many buttons to use, very simplified. Controls for bass, mid, treble, AND subs, I really like the sound on CD with this deck. A nice option on this deck is the ability to turn on or off the 47 w x 4 power from the head unit....The head unit was easy to install. A shot of it is in the first pic.....
The Audison SRX4 amp puts out 60w x 4 in a 4ohm setup, with options for a 2 or 3 channel system.....I went with the 4 channel of course, low bypasses in the doors for the subs, full sound in the dash speaks. A pic of it is below before I ran the pre outs from the head unit under the carpet....All that is needed is a surround with cutouts for the wires leading from the amp, and a top with hinges to close up the amp area so I can still use it to put stuff in .....and a little grey carpet, and voila!
All in all it was a learning experience for sure!
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
