			It could be possible that you are turning in too fast, and quickly breaking the grip of the front tires.  It sounds like your turn entry speeds are just a bit too high.  Enter the corner slower so you can get back on the gas earliers, and that will get you around the track faster than reducing your braking.  I've never had a problem understeering at the track.
 BTW, what tire pressures were you using?  I don't go with stock pressures at the track.  IIRC, I use somewhere around 32-34 cold all the way around.
