Old 05-30-2010, 04:53 PM   #2
m208334
The diagram indicates that pin 7 turns the changer on/off, pin 8 provides constant 12V power and pin 9 is the ground. I am not 100% sure if the CD ON signal has enough juice to operate the system correctly if you just connect pins 7 & 8 together. I would keep the 12V power and CD On/Off signals in separate wires.
m208334 is offline   Reply With Quote
