Originally Posted by Oaktown 986
It runs and drives, just very poorly (considering it was running like a top a couple weeks back) and can't make it past 3k. I manually pulled the throttle cable, thinking that maybe the throttle body blade is stuck or facing resistance, but that didn't help. It's getting fuel and spark, it sounds quite normal at idle. it also has idling problems right after you gas it, but then it quickly returns to a normal idle.
A smooth & normal idle would rule out most electrical issues. Could still be the fuel pump/pressure.
