Old 05-24-2010, 06:38 AM   #3
Trey T
Trey T's Avatar
Typical starting system w/ MT has the clutch switch and starter relay. Immobilizer/DME is independent from the starting system, from what I have seen.
I never worked on porsche but when you have problem like this, I find it best to work backward and test the starter wire and work your way back to the starter relay and back to your ignition switch. It's a pretty simple diagnostic job, IMO. Or the other way around.
Trey T is offline   Reply With Quote
