Old 05-22-2010, 03:53 PM   #6
mojosung
Current distributor - how can I remove it?
Hello, I had problems with the fog light, no power to the relay. Also the low beam, dont know why yet.. so I now traced the curcuit to the current distributor and wanted to check all the fuses there. I loosen up the nuts that hold the current distributor from the battery side, then tried to move the distributor off in the passenger footwell. But then I found the clearence between the current distributor and an air box? Can someone had taken the current distributor off please help me and tell me how you took it off? Thanks.
mojosung is offline   Reply With Quote
