Old 05-20-2010, 04:01 PM   #3
Cartel
Originally Posted by JDBOXSTER
I carefully sawed the old emblem off using dental floss as a saw.
The remaining adhesive was removed with a llittle WD-40 and careful rubbing.
Hope this helps.
JD BOXSTER
Prior to utilizing the dental floss to remove the emblem, I used a hair dryer to soften the glue on the emblem, and it worked like a charm.
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l GiroDisc 340mm FR Rotors l IPD Intake Plenum l Litronics l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
Cartel is offline   Reply With Quote
