Old 05-19-2010, 03:52 AM   #11
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by jrdiesel01
I also followed all these tips ensuring clock spring was not interupted and my new 3 spoke doesnt point straight when driving. Dealer says it has "nothing to due w/clockspring". Kinda makes sense since the shaft should align with wheel (STRAIGHT) before it comes in contact w/clock spring.
with that said, how can i fix this?
Thanks!
Use these instructions and where it tells you to mark the location, mark it and then when you bolt the wheel back on, just bolt the wheel slightly to the left or right depending on how far your steering wheel is off center left or right.
http://www.whiteson.org/boxster/mods/obc/obc.stalk.pdf
