Old 05-17-2010, 06:36 AM   #3
ARModen
Never really seen a procedure for it, and my boxster is automatic, but I have done this work on a 944 and an RX-7. But here's what I've learned from fixing/screwing those up. Generally there is a a master cylinder connected to the pedals, a reservoir on top of the master cylinder, a line from the master cylinder to the slave, and then slave cylinder. If the cylinders have rubber gaskets sealing their plungers, if either have ruptured you'll see a loss of pressure and an oil leak.
I've had the master go, which gave me oil under the pedal inside the car. I've never seen a slave go, but that would give you oil under the car. When I replaced the master cylinder in the RX-7 I failed to torque the bleed valve sufficiently, which caused it to pop off and gave me the same symptoms you saw. On the 944 I had a section of braided steel hose with rubber coating on it. Whenever I pushed the clutch the hose would weep oil, which is very confusing if you're working on the system by yourself, because the oil just seems to appear from no where.
ARModen is offline   Reply With Quote
