Originally Posted by smeech
I changed the battery and started the car. All worked fine except for the ignition. It's still difficult to remove the key and I can't lock the car with the remote. Does this smell of an ignition switch or do you think it is something else as I was able to start the car?
The ignition barrel likely just needs a lube, if you look in the Bentley manual, it has a nice close up of how it comes apart. Mine started doing the same thing, took it apart sprayed it with break free, all is well.
