Old 06-30-2005, 07:23 AM   #12
deliriousga
deliriousga's Avatar
Sorry JP, didn't mean to hijack your thread. The water pump will usually leak when it reaches the end of its' life to let you know it's about to go.
Have you taken the belly pans off? The water could be dripping somehwere else and just rolling along the pans until it finds a hole by the driver's seat to get out. Also, look around at the hoses under there and see if you've got one leaking.
It's tough to really see what's going on until you take the pans off. The bolts are all the same size (I think 10mm, but could be 8mm. Definitely one of those two) so it's easy to pull them. If you put it up on stands, make sure they are wide-based stands so they don't tip easy and put a floor jack (with just light pressure) underneath in a sturdy location just in case.
If you can't find it from underneath or in the trunk, take the engine cover off behind the seats. Once it's off, you can see the front of the engine including the water pump. You should be able to see the thermostat housing from either the top of the engine or the front, not sure which.
1966 Wife White/Brown Top
